HTPC или мультимедиа центр своими руками.
На страницу Пред.  1, 2, 3 ... 29, 30, 31, 32, 33  След.
BNX
СообщениеДобавлено: 14.07.2011 22:14    Заголовок сообщения: Ответить с цитатой
Pavki писал(а):
есть идеи?
Есть - Правила прочитай для начала. Замечание!
BNX
СообщениеДобавлено: 15.07.2011 07:16    Заголовок сообщения: Ответить с цитатой
Наткнулся на еще один интересный девайс для Медиа-PC:
PCI-E DVB-S2 Quad Tuner TV card supports 4 DVB-S2 TV channels receiving synchronously, which enables you to watch channel from one transporder/satellite while recording another 3 channels from another 3 transporders / satellites. Or you can download data from 4 transporders / satellites in the same time.
TBS6984 is ideal for building HTPC under Linux MythTV, VDR, XBMC and Windows 7 Media Center.
TBS6984 is compatible with Freesat.
Main Features:
Quad Channels DVB-S2/S HD/SD TV Receiving Synchronously
Broadband via Internet
High-speed Data Download via Satellite
Linux S2API Drivers Compatible with MythTV, VDR, XBMC, DVBLast, VLC, etc.
Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, Tsreader etc
Specifications:
Receiving Frequency: 925~2175 MHz Tuning Range
Input Level: -69~23dBm
4x Advanced DVB-S2/DVB-S 8PSK QPSK Demodulator
Symbol Rates:
DVB-S QPSK: 1-45 Msps
DVB-S2 8PSK/QPSK: 2-36 Msps
Code Rates:
DVB-S: 1/2, 2/3, 3/4, 5/6, 7/8
DVB-S2 QPSK: 1/2, 3/5, 2/3, 3/4. 4/5. 5/6, 8/9, 9/10
DVB-S2 8PSK: 3/5, 2/3. 3/4. 5/6. 8/9, 9/10
Automatic Acquisition Range: ±10MHz
DiSEqC 2.x Compliant
PCI Express Interface
System Requirements:
Windows 2000 / XP / Vista / 7, Linux
DirectX9.0 or later Version
Available PCI slot
CD-Rom(Driver and Software Installation)
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV (1080i/ MPEG4 <AVC/ H2.64> ):
3.0GHz Penium IV CPU or above
1GB RAM or Above
Graphic Card with at Least 64MB RAM
Package Content:
1 x TBS6984 PCI-E Dual DVB-S2 Tuner card
1x Remote control
1x IR receiver
1x Software CD
1x Power Cable
СообщениеДобавлено: 15.07.2011 08:05    Заголовок сообщения: Ответить с цитатой
Глючно она работает. И не одна она, а все DVB карты построенные по этому принципу. На неё стоит микросхема USB контроллера а к его портам приделаны DVB устройства на микросхемах предназначенных изначально для USB DVB карт.
Может драйверы отточат и заработает. А пока счастливые (несчастные) обладатели сего и подобных дивайсов борются с глюками с переменным успехом.
СообщениеДобавлено: 15.07.2011 08:17    Заголовок сообщения: Ответить с цитатой
т.е. PCI-e на этой карте по сути фикция раз DVB сидят на УСБ огорчение
СообщениеДобавлено: 15.07.2011 08:57    Заголовок сообщения: Ответить с цитатой
Ну не совсем фикция. Справа внизу в BGA исполнении это и есть USB контроллер. За тюнерами два чипа это двухканальные контроллеры (они поток как раз и обрабатывают) но с интерфесом USB и два двухканальных тюнера.
Теоретически если отпилить USB контроллер, запитать карту соответсвующими напряжениям 12, 5, 3.3 вольта то её можно в USB компьютера воткнуть.
СообщениеДобавлено: 15.07.2011 09:11    Заголовок сообщения: Ответить с цитатой
Я к тому, что этой плате хватило PCI
СообщениеДобавлено: 15.07.2011 10:36    Заголовок сообщения: Ответить с цитатой
Аналогичная DVB-карта TeVii S480 PCI-E.
Лично мое мнение, уж если решили переплюнуть восьмитысячный дрим, поставьте две нормальных PCI-карты.
DM800HD SE, DM7020HD, DM7080HD
СообщениеДобавлено: 15.07.2011 10:52    Заголовок сообщения: Ответить с цитатой
Эта четыре в одном.
Мысль то конструкторов понятна. Поставили четырехканалный контроллер USB и получили масштабируемую технологию. TeVii S480 PCI-E двухканальная и у TBS есть двухканальная. Так как на каждый USB порт подключено по двухканальной USB DVB то теоретический предел 8 в одной.
Как бы сделали базовую конструкцию, а потом без особых усилий растягивай её до 8 каналов.
СообщениеДобавлено: 15.07.2011 11:32    Заголовок сообщения: Ответить с цитатой
Эта четыре в одном.
Вон оно что.
Интересно, какую цель преследовали разработчики карты. Неужели путем увеличения приемных устройств отказаться от переключателей.
СообщениеДобавлено: 15.07.2011 12:22    Заголовок сообщения: Ответить с цитатой
Ну а вдруг четыре интересных фильма одновременно пойдут с разных транспондеров и спутников. Три штуки пишешь, один смотришь широкая улыбка
Или рыбачить сразу с четырех провайдеров. Только пока с рыбалкой там не очень. У карт с такой схемотехникой почему то от дисконтов никому избавится не удалось.
Последний раз редактировалось: Lenchik (15.07.2011 13:04), всего редактировалось 1 раз
СообщениеДобавлено: 15.07.2011 12:42    Заголовок сообщения: Ответить с цитатой
Ну а вдруг четыре интересных фильма одновременно пойдут с разных тарнспондеров и спутников. Три штуки пишешь, один смотришь
Понял, эта карта разработана под НТВ-плюс, специально для кинорейсов.
СообщениеДобавлено: 15.07.2011 18:53    Заголовок сообщения: Ответить с цитатой
потому что обе карты на одном усб висят улыбка
СообщениеДобавлено: 15.07.2011 20:10    Заголовок сообщения: Ответить с цитатой
У SPC1400HD один тюнер (NIM модуль) а проблема та же.
BNX
СообщениеДобавлено: 01.08.2011 09:51    Заголовок сообщения: Ответить с цитатой
Интересный девайс поставили "на поток"
http://habrahabr.ru/blogs/DIY/125322/
Не понятно пока, что у него с USB и можно ли будет подключить DVB карту, но если да - будет "бомба" широкая улыбка
СообщениеДобавлено: 01.08.2011 10:26    Заголовок сообщения: Ответить с цитатой
BNX
Ну если дрова сам напишешь, то да подмигивание
BNX
СообщениеДобавлено: 01.08.2011 11:54    Заголовок сообщения: Ответить с цитатой
zhiv Что? Есть на руках такая плата?
yuri_sh
СообщениеДобавлено: 12.08.2011 08:33    Заголовок сообщения: Ответить с цитатой
Как обещал ранее выкладываю фото по сборке:
Собственно...и все.
Замечу - корпус очень качественно изготовлен, собирать такие корпуса одно удовольствие.
Успехов.
SatCat
СообщениеДобавлено: 12.08.2011 13:25    Заголовок сообщения: Ответить с цитатой
Как звать корпус?
yuri_sh
СообщениеДобавлено: 12.08.2011 13:43    Заголовок сообщения: Ответить с цитатой
SatCat писал(а):
Как звать корпус?
Корпус Desktop Micro ATX SilverStone Grandia SST-GD05B без БП
http://rostov-na-donu.dns-shop.ru/catalog/88/127149/
СообщениеДобавлено: 12.08.2011 14:45    Заголовок сообщения: Ответить с цитатой
yuri_sh
Поздравляю! Полный джентельменский набор.
Интересно, какую DVB-карту используете, на фото плохо. И еще, удобно ли пользоваться телевизором в качестве монитора.
СообщениеДобавлено: 12.08.2011 15:11    Заголовок сообщения: Ответить с цитатой
Смотря для чего?
Если по инету немного по лазить, то нормально.
А если в ворде или не дай бог фотошопе или каком нибуть каде то жуть!
yuri_sh
СообщениеДобавлено: 12.08.2011 16:05    Заголовок сообщения: Ответить с цитатой
Спасибо.
Если честно...то карту пока убрал, на первой фоте она есть, а потом нет подмигивание
Лично мне - очень удобно, 47'' с 3 метров смотрится комфортно.
И кино и в нете полазить.
На предпоследнем фото лежит пульт и ИК приемник.
Успехов.
СообщениеДобавлено: 12.08.2011 16:12    Заголовок сообщения: Ответить с цитатой
Несколько раз пытался подменить монитор телевизором, не понравилось, постоянно приходиться крутить головой. Если экран монитора охватываешь одним взглядом, то с телевизором так не получается. Приходится распологаться подальше, тогда плохо видно буквы. Да и вопрос с управлением компьютера, радиоклавиатуру держишь на коленях, что то же не очень удобно.
СообщениеДобавлено: 12.08.2011 16:46    Заголовок сообщения: Ответить с цитатой
А журнальный столик на колесиках "спасет отца русской демократии" (С) ? голливудская улыбка
СообщениеДобавлено: 12.08.2011 17:04    Заголовок сообщения: Ответить с цитатой
Думаю, что надо что-то делать с интерером комнаты. Особо не разгуляешься, когда почти половину комнаты занимает двухспальняя кровать.
Страница 30 из 33
