Constantine_S новый
Зарегистрирован: 20.02.2008 Сообщения: 2 Откуда: Russia, Matveykovo
Добавлено: 20.02.2008 18:44 Заголовок сообщения: переставил винду-морда мигает зеленым -браузер не показывает |
Доброго времени суток. Появилась проблема. Переставил винду, установил двб дата, ускоритель, все настройки воткнул. Наземная связь через гпрс. Запрос вроде уходит, рожица зеленым мигает, траф идет, а браузер ничего не кажет!!!!!!! ПОМОГИТЕ!!!!, а в логе ускорителя вот такая ситуэйшн:
MSG:2006-12-08 20:32:50.593:Program started =============
MSG:2006-12-08 20:32:50.593:Watchdog starting... [3256]
MSG:2006-12-08 20:32:50.593:Watchdog started [3256].
MSG:2006-12-08 20:32:50.640:Starting new child...
MSG:2006-12-08 20:32:50.640:Started new child [740].
MSG:2006-12-08 20:32:50.890:tc-recv.exe starting... [740]
MSG:2006-12-08 20:32:50.890:tc-recv.exe version is 2.4.4a (200608041259682) win32-i86pc (Windows XP Professional, Version 5.1.2600, Service Pack 2 on a 2-processor (GenuineIntel, Pentium 4 (Model 67, Stepping 3)) system)
MSG:2006-12-08 20:32:50.890:Log level is "normal".
MSG:2006-12-08 20:32:50.968:tc-recv.exe running [740].
MSG:2006-12-08 20:33:07.937:Connected to ETCP server 82.211.152.8:9200
MSG:2006-12-08 20:34:08.953:Closing association (ip 82.211.152.: An outstanding acknowledge pdu was not received in time (probably high udp data loss).
MSG:2006-12-08 20:34:08.953:Closing association: An outstanding acknowledge pdu was not received in time (probably high udp data loss)
MSG:2006-12-08 20:34:13.281:Connected to ETCP server 82.211.152.8:9200
MSG:2006-12-08 20:35:14.281:Closing association (ip 82.211.152.: An outstanding acknowledge pdu was not received in time (probably high udp data loss).
MSG:2006-12-08 20:35:14.281:Closing association: An outstanding acknowledge pdu was not received in time (probably high udp data loss)
MSG:2006-12-08 20:39:57.109:tc-recv.exe shutting down... [740]
MSG:2006-12-08 20:39:57.125:tc-recv.exe stopped [740].
MSG:2006-12-08 20:39:57.171:Watchdog child quits properly. Shutting down.
MSG:2006-12-08 20:39:57.171:Watchdog shutting down ... [3256]
MSG:2006-12-08 20:39:57.187:Watchdog stopped [3256].
ПЛИИЗ помогите - я уже не наю че делать.
Заранее,
СПААААСИБО!!!! |
uantonio свой
Зарегистрирован: 30.12.2007 Сообщения: 41 Откуда: Московская обл.
Добавлено: 20.02.2008 19:09 Заголовок сообщения: |
У меня такая же проблема,только ускоритель сам по себе без переустановке винды перестал работать,хотя я вроде в файле конфигурации я ничего не менял.Бился я с супортом и логи показывал и конфигурац.файл показывал,ничего они мне хорошего не подсказали.Решил я эту проблему так:у меня был реальный IP который я взял у planetsky чтобы глобаксом пользоваться и это IP я записал заместо старого в файл конф.ускорителя и о чудо,заработало! |
Constantine_S новый
Добавлено: 20.02.2008 20:34 Заголовок сообщения: |
извините, а можно по подробнее? что за ай пи и куда его переписывать??? |
uantonio свой
Добавлено: 20.02.2008 21:06 Заголовок сообщения: |
Пообщайся со службой поддержки,спраси какой ip для твоеё подписки.Может ты просто забыл вписать в свойства DVB карты ip адрес?И покажи свой конфигурационный файл от ускорителя. |
