Goga свой
Netman свой
Зарегистрирован: 23.08.2006 Сообщения: 145 Откуда: Россия, г.Барнаул <53°21'сш-83°47'вд>
Добавлено: 16.12.2007 16:44 Заголовок сообщения: |
Каналы идут в каком-то странно формате, который MPlayer не может понять:
| Код: | $ cat /dev/dvb/adapter0/dvr0 | mplayer -vc coreavc13 -demuxer lavf -vo x11 -msglevel all=9 -
==> Found video stream: 0
[lavf] Video stream found, -vid 0
aspect= 0*0/(0*1)
======= VIDEO Format ======
biSize 40
biWidth 0
biHeight 0
biPlanes 0
biBitCount 0
biCompression 828862573='mpg1'
biSizeImage 0
==> Found audio stream: 1
[lavf] Audio stream found, -aid 1
======= WAVE Format =======
Format Tag: 80 (0x50)
Channels: 2
Samplerate: 48000
avg byte/sec: 24000
Block align: 1
bits/sample: 0
cbSize: 0
LAVF: 1 audio and 1 video streams found
LAVF: build 3408384
VIDEO: [mpg1] 0x0 0bpp 90000.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:35 fourcc:0x3167706D size:0x0 fps:90000.00 ftime:=0.0000
get_path('sub/') -> '/home/netman/.mplayer/sub/'
X11 opening display: :0.0
vo: X11 color mask: FFFFFF (R:FF0000 G:FF00 B:FF)
vo: X11 running at 1152x864 with depth 24 and 32 bpp (":0.0" => local display)
[x11] Detected wm supports NetWM.
[x11] Detected wm supports FULLSCREEN state.
[x11] Detected wm supports ABOVE state.
[x11] Detected wm supports BELOW state.
[x11] Detected wm supports STAYS_ON_TOP state.
[x11] Current fstype setting honours FULLSCREEN STAYS_ON_TOP ABOVE BELOW X atoms
[xv common] Drawing no colorkey.
[xv common] Maximum source image dimensions: 2046x2046
Forced video codec: coreavc13
Cannot find codec matching selected -vo and video format 0x3167706D.
Read DOCS/HTML/en/codecs.html!
*** uninit(0x1)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
dec_audio: Allocating 4608 + 65536 = 70144 bytes for output buffer.
mp3lib: using SSE optimized decore!
MP3lib: init layer2&3 finished, tables done
demux_lavf_fill_buffer()
MPEG 1.0, Layer II, 48000 Hz 192 kbit Stereo, BPF: 576
Channels: 2, copyright: No, original: No, CRC: Yes, emphasis: 0
AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
Building audio filter chain for 48000Hz/2ch/s16le -> 0Hz/0ch/??...
[libaf] Adding filter dummy
[dummy] Was reinitialized: 48000Hz/2ch/s16le
ao2: 48000 Hz 2 chans s16le
audio_setup: using '/dev/dsp' dsp device
audio_setup: using '/dev/mixer' mixer device
audio_setup: using 'pcm' mixer device
[AO OSS] audio_setup: Can't open audio device /dev/dsp: Device or resource busy
alsa-init: requested format: 48000 Hz, 2 channels, 9
alsa-init: using ALSA 1.0.15rc1
alsa-init: setup for 1/2 channel(s)
alsa-init: using device default
alsa-init: pcm opened in blocking mode
alsa-init: chunksize set to 1024
alsa-init: fragcount=16
alsa-init: got buffersize=65536
alsa-init: got period size 1024
alsa: 48000 Hz/2 channels/4 bpf/65536 bytes buffer/Signed 16 bit Little Endian
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
AO: Description: ALSA-0.9.x-1.x audio output
AO: Author: Alex Beregszaszi, Zsolt Barat <joy@streamminister.de>
AO: Comment: under developement
Building audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
Video: no video
Freeing 0 unused video chunks.
Starting playback...
Increasing filtered audio buffer size from 0 to 65536
demux_lavf_fill_buffer()f 0.0 (unknown) ??,?%
demux_lavf_fill_buffer()f 0.0 (unknown) 0.9%
Обратите внимание на:
| Цитата: | ...
_________________ Hi! I'm a signature virus. Copy me into your signature to help me spread. |
Goga свой
Добавлено: 16.12.2007 18:23 Заголовок сообщения: |
вот так пробуйте
dvbstream -o 8192 | mplayer -
или
dvbsnoop -s ts -b -tsraw | mplayer -
только вначале эти 2 проги установите, если они еще тоят на вашем компе. |
Netman свой
Добавлено: 16.12.2007 19:32 Заголовок сообщения: |
MPlayer вылетает при попытке открыть кодек:
| Код: | $ dvbsnoop -s ts -b -tsraw | mplayer -vc coreavc13 -
MPlayer dev-SVN-r25419-4.2.2 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Pentium(R) 4 CPU 1.80GHz (Family: 15, Model: 2, Stepping: 4)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
117 audio & 240 video codecs
Playing -.
Reading from stdin...
Cannot seek backward in linear streams!
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Seek failed
Win32 LoadLibrary failed to load: avisynth.dll, /usr/lib/codecs/avisynth.dll, /usr/lib/win32/avisynth.dll, /usr/local/lib/win32/avisynth.dll
Seek failed
Seek failed
Seek failed
TS file format detected.
Seek failed
VIDEO H264(pid=151) AUDIO MPA(pid=152) NO SUBS (yet)! PROGRAM N. 27015
Seek failed
FPS seems to be: 25.000000
Opening video decoder: [dshow] DirectShow video codecs
MPlayer interrupted by signal 11 in module: init_video_codec
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
Goga свой
Добавлено: 16.12.2007 19:39 Заголовок сообщения: |
а мплеер патченный для coreavc for linux у вас ?
если без -vc coreavc13 попробовать на непатченном мплеере ? |
Netman свой
Добавлено: 16.12.2007 20:20 Заголовок сообщения: |
| Goga писал(а): | а мплеер патченный для coreavc for linux у вас ?
MPlayer патченый.
Если запускать без -vc coreavc13, то будет использоваться ffmpeg - конечно же, в этом случае в логе будут ошибки, о которых вы выше говорили.
Но у меня то задача - использоваться CoreAVC - а не ffmpeg!
Кстати, я продвинулся еще на шаг дальше - теперь кодек открывается, но появилась следующая проблема (постарался выбрать из всего однообразия аписей самые информативные куски - может, будет полезно):
| Код: | $ dvbsnoop -s ts -b -tsraw | mplayer -vc coreavc13 -demuxer lavf -vid 13 -aid 14 -vo x11 -msglevel win32=9
Playing -.
libavformat file format detected.
LAVF: Program 27000 TricolorTV
[lavf] Video stream found, -vid 10
LAVF: Program 27005 ^......
[lavf] Video stream found, -vid 11
[lavf] Audio stream found, -aid 12
LAVF: Program 27010 ^......
LAVF: Program 27015 ^........
[lavf] Video stream found, -vid 8
[lavf] Audio stream found, -aid 9
LAVF: Program 27020 NTV
[lavf] Video stream found, -vid 13
[lavf] Audio stream found, -aid 14
LAVF: Program 27025 ^.....
[lavf] Video stream found, -vid 4
[lavf] Audio stream found, -aid 5
LAVF: Program 27030 Test6
[lavf] Video stream found, -vid 15
[lavf] Audio stream found, -aid 16
LAVF: Program 27040 Test7
[lavf] Video stream found, -vid 17
[lavf] Audio stream found, -aid 18
LAVF: Program 27050 ^½.
[lavf] Video stream found, -vid 2
[lavf] Audio stream found, -aid 3
LAVF: Program 27060 ^.....
[lavf] Video stream found, -vid 6
[lavf] Audio stream found, -aid 7
LAVF: Program 27070 ^...-²
[lavf] Video stream found, -vid 19
VIDEO: [H264] 720x576 0bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
tid:b67806e0 External func advapi32.dll:RegCreateKeyW
tid:b67806e0 External func advapi32.dll:RegSetValueW
tid:b67806e0 External func advapi32.dll:RegSetValueExW
tid:b67806e0 GetVersionExA(0x85c191b) => 1
tid:b67806e0 Major version: 4
Minor version: 0
Build number: 0x4000457
Platform Id: VER_PLATFORM_WIN32_NT
Version string: 'Service Pack 3'
tid:b67806e0 GetProcessHeap() => 1
tid:b67806e0 HeapFree(0x1, 0x0, pointer 0x8ac2038) => 1
tid:b67806e0 EnterCriticalSection(0x100a0cd0) 0x9825b40
tid:b67806e0 LeaveCriticalSection(0x100a0cd0) 0x9825b40
tid:b67806e0 RegOpenKeyExA(key 0x80000001, subkey Software\CoreCodec\CoreAVC Pro, reserved 0, access 0x20019, pnewkey 0xbf85d608) => 0
tid:b67806e0 New key: 0xfa
tid:b67806e0 RegQueryValueExA(key 0xfa, value DisabledInputFormat, reserved 0x0, data 0xbf85d610, count 0xbf85d60c) => 0x2
tid:b67806e0 read 510 bytes: ''
tid:b67806e0 RegCloseKey(0xfa) => 1
tid:b67806e0 New key: 0xfb
tid:b67806e0 LeaveCriticalSection(0x8db4e14) 0x97bc040
Decoder is capable of YUV output (flags 0x27)
VDec: vo config request - 720 x 576 (preferred colorspace: Packed YUY2)
[PP] Using codec's postprocessing, max q = 4.
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.36:1 - prescaling to correct movie aspect.
VO: [x11] 720x576 => 786x576 Planar YV12
tid:b67806e0 EnterCriticalSection(0x8db4e14) 0x97bc040
Selected video codec: [coreavc13] vfm: dshow (CoreAVC DShow H264 decoder 1.3 for x86 - http://corecodec.org/)
tid:b67806e0 EnterCriticalSection(0x8db4e2c) 0x9072070
tid:b67806e0 HeapAlloc(heap 0x8ac2038, flags 0x0, size 12288) => 0x8c20410
[h264 @ 0x883b010]no frame!
[h264 @ 0x883b010]non existing PPS referenced
[h264 @ 0x883b010]decode_slice_header error
[swscaler @ 0x8839588]SwScaler: using unscaled yuv420p -> rgb32 special converter
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
*** glibc detected *** mplayer: realloc(): invalid next size: 0x08de00e8 ***
======= Backtrace: =========
/lib/i686/libc.so.6[0xb73272a3]
/lib/i686/libc.so.6(realloc+0x10d)[0xb732927d]
mplayer[0x85cc66f]
[0x10004662]
======= Memory map: ========
08048000-087fd000 r-xp 00000000 03:03 304575 /usr/bin/mplayer
087fd000-0884f000 rwxp 007b5000 03:03 304575 /usr/bin/mplayer
0884f000-099fe000 rwxp 0884f000 00:00 0 [heap]
10000000-100c2000 rwxp 00000000 03:03 253941 /usr/local/lib/codecs/CoreAVCDecoder.ax
b6100000-b6121000 rwxp b6100000 00:00 0
MPlayer interrupted by signal 6 in module: decode_video
won't help unless you provide this information when reporting a possible bug. |
Goga свой
Добавлено: 16.12.2007 22:58 Заголовок сообщения: |
на этом мои идеи закончились. Я не имел дела с патченным для core-avc мплеером, но судя по логам имеются серьезные проблемы. Я желаю вам успеха. Напоследок, еще одна ссылка на пару патчей, первый патч (который прямого отношения к coreavc не имеет, но может быть полезным)
http://lists.mplayerhq.hu/pipermail/mplayer-users/2006-March/058772.html
а также патч, который обсуждался в треде про coreavc for linux
http://lists.mplayerhq.hu/pipermail/mplayer-dev-eng/2007-July/052959.html
Alan Nisota wrote:
> Mplayer does not seem to have the capability to deal with the fact that
> CoreAVC does the deinterlacing internally, and so I have been unable to
> make mplayer work with interlaced AVC streams, but MythTV and Xine can
> both handle it. I have no plans to try to fix mplayer for this.
I fixed the decoding of transport streams containing PAFF encoded video
for mplayer -correct-pts -demuxer lavf -vc coreavc (but unfortunately
not for mencoder). It is likely that this change leads to a small (but
constant) A/V desync, because some frames in the beginning of the stream
will be skipped.
In loader/dshow/DS_VideoDecoder.c, the following line has to be added
after "sample->vt->Release((IUnknown*)sample)" (around line 447):
if (!framecount) return -1;
And the following, inlined patch has to applied to libmpcodecs/vd_dshow.c.
On fast computers, this should allow playback of PAFF encoded videos
with mplayer and coreavc.
Carl Eugen
Index: libmpcodecs/vd_dshow.c
--- libmpcodecs/vd_dshow.c (Revision 24350)
+++ libmpcodecs/vd_dshow.c (Arbeitskopie)
@@ -109,7 +109,8 @@
return NULL;
- DS_VideoDecoder_DecodeInternal(sh->context, data, len, 0,
mpi->planes[0]);
+ if (DS_VideoDecoder_DecodeInternal(sh->context, data, len, 0,
mpi->planes[0])<0)
+ return NULL;
return mpi;
_______________________________________________
MPlayer-dev-eng mailing list
MPlayer-dev-eng@mplayerhq.hu
http://lists.mplayerhq.hu/mailman/listinfo/mplayer-dev-eng |
VA свой
Добавлено: 10.05.2008 19:53 Заголовок сообщения: |
Ох давно не видал..... спасибо всем кто мне тогда помогал, So*ftcam плугин я собрал и кафеин завел..... Собрал себе новое ядро и с ним завел драйвер DS110, сапсибо igorli.... Не смог только одно, управлять мотором, ни DS110, ни ТТ-1401
Кто что может подсказать в этом направлении?
PS: каффеин хорогая прога, но очень неудобная в плане списков каналов. По провайдеру/сети не сгруппировать, по спутнику тоже. Может кто то посоветует хороший фронтэнд к xine или vdr? _________________ Вологда (59°13"-39°54") |
Seliger свой
Зарегистрирован: 04.12.2006 Сообщения: 36 Откуда: г. Йошкар - Ола
Добавлено: 10.05.2008 20:31 Заголовок сообщения: |
| Netman писал(а): | Kaffeine показывает эти каналы! При чем без лишних движений с моей стороны |
Странно, но у меня только звук ... Кодеки Win32 установлены и нормально функционируют, а вот Каффеин никак не хочет показать картинку ... Mpeg2 показывает отлично! Заметил странность:
- вроде как неверно определяет размер видео ...
Пока не представляю, в каком направлении искать проблему ...
Kaffeine 0.8.5 на KDE 3.5.8 - Kubuntu (Debian) 7.10 |
alexaga бывалый
Добавлено: 10.05.2008 21:16 Заголовок сообщения: |
У линукс вроде свои кодеки и они прекрасно работают.
А как ставить виндовские кодеки? Честно говоря и непробовал. |
Seliger свой
Добавлено: 11.05.2008 09:49 Заголовок сообщения: |
Пакет называется 'w32codecs_20071007-0medibuntu1_i386.deb' , нужен для воспроизведения wmv, wma и прочих специфичных форматов аудио и видео. Официальное описание:
Win32 codec binaries
This package contains Win32 codec binaries, required for the decompression of video formats that have no open source alternative.
Homepage: http://www4.mplayerhq.hu/ |
alexaga бывалый
Добавлено: 11.05.2008 14:07 Заголовок сообщения: |
Это я знаю но не пробовал. Для Убунты я использовал пакет GStreamer ffmpeg video plugin. Всё без проблем завелось. Кубунту не исользую не понравилась оболочка. Но думаю особого отличия нет.
Вот сайт разрабочика http://gstreamer.freedesktop.org/ |
Seliger свой
Добавлено: 11.05.2008 15:26 Заголовок сообщения: |
Хм ... я пытался использовать GStreamer в качестве движка к Каффеину ... Каффеин работает, локальные видеофайлы отлично вопроизводит, при переключении на закладку 'DVB' заботливо вылетает сообщение ' "Живой" просмотр возможен только с движком xine ' ... Как ни крути, приходится использовать xine ...
По сути это неудивительно, Kaffeine прожка из поставки KDE, а мультимедиа движок в КДЕ именно Xine ...
Удивительно, в неродной графической оболочке (то есть в Гноме) Kaffeine всё таки умеет полностью работать на GStreamer ??? Как то это псевдонаучно ...
Или у меня версия кривая??? Всё уже попробовал ... |
alexaga бывалый
Добавлено: 11.05.2008 16:37 Заголовок сообщения: |
Вроде без проблем всё уживается под гномом.
http://radikal.ru/F/i028.radikal.ru/0805/72/486c01f0dc2b.jpg.html
Я просто чайник в линуксе. Многово не понимаю. Читаю доки по гуглу. Вроде пока всё получается. Уже как пол года на убунте 7.10 и обратно не тянет.
Единствеено что пока без результано не могу прикрутить нормально DS120 на убунте 7.10. Проблема ясна, из-за ядра. Но копаться бросил. Т.к. с выходом убунты 8.04 всё решилось само сабой.
ТТ - 1401 работает на разных дистрибутивах без казусов. SS2 тоже всё тип топ.
В убунте кроме плагинов и кодеков от GStreamer нечего нет. Больше нечего не ставил.
Вот это скрин не мой igorli взят с форума www.ddixlab.ru
http://radikal.ru/F/i013.radikal.ru/0805/81/4335848e409e.jpg.html
У меня точно также на стационарнике. Без проблем. |
VA свой
Добавлено: 11.05.2008 21:44 Заголовок сообщения: |
так оно, у меня 0.8.6 (убу 8.04) c Gstreamer с DVB не работает.....
А DS 110 я поставил попутно собрав себе свежее ядро. Это не так сложно как может показаться. _________________ Вологда (59°13"-39°54") |
Seliger свой
Добавлено: 11.05.2008 21:52 Заголовок сообщения: |
В подтверджение слов:
Если тут выбираем GStreamer,
и пытаемся переключится на вкладку ТВ, то получаем следующее сообщение:
alexaga, на вашем скрине и есть настройки xine, он и используется ... Kaffeine его сам стянул наверное в заваисмостях или amaroK ...
Продолжаю поиски проблемы ... |
alexaga бывалый
Добавлено: 11.05.2008 22:08 Заголовок сообщения: |
VA вы с какого сервера грузили приложения на убунту 8.04? Т.к. уже неделю не могу обновится толком. Сервер русский перегружен. Кофейн стоит 0.8.5. И в убунте 8.04 уже не надо пересобирать ядро там уже изночально 2.6.24. В 7.10 - ядро 2.6.22 там нужно танцевать малость с бубном. Но ядро переустанавливать на 7.10 не стал. Ждал 8.04. А на стационарнике стояла Мандрва 2008 с новым ядром 2.6.25. В ней так вообще всё с пол пинка завелось.
Для кофейна нужно ставить xine . Далее просто выбираем настройки прописываем нужный DVB адаптер присвоенный системой (т.к у меня не одна карта) и всё. Нечего особого. Ну и дрова нужно к видео карте ставить. Иначе не гуд будет при воспроизведение видео.
Seliger может быть. Но кодеков ни каких более не ставил. И у меня нет вкладки в Кофейне GStreamer Мож чего нахимичил.
В общем буду с нуля уже с 8.04 колдовать. Я ведь только учусь потихоньку. |
VA свой
Добавлено: 12.05.2008 14:58 Заголовок сообщения: |
| Цитата: | | VA вы с какого сервера грузили приложения на убунту 8.04? Т.к. уже неделю не могу обновится толком. |
Офф. зеркало на яндексе (mirror.yandex.ru). На самом деле вытяните себе торрентом alternate и обновитесь с диска, так лучше будет. А еще лучше форматнуть всё кроме /home и поставить начисто.
| Цитата: | | И в убунте 8.04 уже не надо пересобирать ядро там уже изночально 2.6.24. В 7.10 - ядро 2.6.22 там нужно танцевать малость с бубном. Но ядро переустанавливать на 7.10 не стал. Ждал 8.04. А на стационарнике стояла Мандрва 2008 с новым ядром 2.6.25. В ней так вообще всё с пол пинка завелось. |
Так да, 2.6.24-16, сейчас ужк 2.6.24-17, но это старье, 2.6.25.2 собрал себе сам и проблем не имею.
| Цитата: | Для кофейна нужно ставить xine . Далее просто выбираем настройки прописываем нужный DVB адаптер присвоенный системой (т.к у меня не одна карта) и всё. Нечего особого. Ну и дрова нужно к видео карте ставить. Иначе не гуд будет при воспроизведение видео.
Дрова вопрос отдельный, конечно надо, в убу для дефолтных ядер через менеджер проприетарных дров, иначе руками, с сайта nVidia, но это не сложно.
Кофейня без xine не ставится, оно тянется как зависимостью сразу из репозитария.
Все мы учимся _________________ Вологда (59°13"-39°54") |
alexaga бывалый
Добавлено: 14.05.2008 08:55 Заголовок сообщения: |
Докладываю об проделанной работе.
Установил Убунту 8.4 пакет кодеков и плагинов от GStreamer. Кафейню последнию. Которая была в списке обновлений. (Вчера под вечер сервер ожил и успел скачать всё необходимое) Драйвер на видеокарту от Hвидиа. Дрова от Акорпа встали без проблем. Ещё раз спасибо igorli. Ядро не менял не собирал. Просто прислушался к советам создателя дров под Линукс. И всё спокойно установилось. Для ТТ-1401 вообще не надо нечего всё заложенно уже в ядро убунты 8.04.
Вот скрин потверждающее что говорил выше.
Нечего не химичил и не танцевал с бубном. Всё кажет и работает.  |
Seliger свой
Добавлено: 15.05.2008 18:03 Заголовок сообщения: |
Теперь и мне есть что сказать
Установлена всё та же Кубунту, правда обновил ядро до более свежего 2.6.24, но думаю это не играет никакой роли в просмотре DVB ...
Ставил - переставил все кодеки, перековырял всю Кофейню, ну никак не хочет показывать видео в H264 ... Ну да ладно ... (Искал в инете, как оказалось, не у одного меня такая странная проблема, более ли менее адекватного решения не видел и предложить не могу )
Но! Какраз по руку попался VLC, вполне адекватный плейер, и о чудо! Все каналы с АМ1 без труда были найдены и работают, есть весьма удобные тонкие настройки кодеков и т.д., правда немного неудобная навигация, точнее нужно сохранять список каналов в плейлист ... в кофейне, бесспорно, продумано намного лучше.
Загрузка процессора при посмотре одного канала в "масштабе" 1:1 около 25% (AMD Athlon X2 3800+), никаких проблем и глюков при просмотре не замечено. (Сообщают, что может "подвисать" Compiz, но это касается и Кофейни ... У меня не подвисал ...)
Кому интересно - в эфире "Вести" (скрин) |
Vitalik Slivkov свой
Добавлено: 03.06.2008 22:36 Заголовок сообщения: |
Полемика была перенесена из http://www.forum.alyno.ru/phpBB2/viewtopic.php?p=112253#112253
| alexaga писал(а): | | Иначе зачем на том же линуксе пишут для Free i586, Free x86_64? |
А все просто - это уже собранные бинарные пакеты. Никто не запрещает собрать на вашем стареньком 386DX пакеты для Core Duo 2 . Все ведь написано на языке С, а он процессоро-независимый язык. Конечно, есть нюансы, в виде портов, адресации и вообще драйверов. Вот тут и начинаются пляски с бубном, которые должны быть дописаны или вообще переписаны.
Скажем есть такой процессор Sparc http://ru.wikipedia.org/wiki/SPARC, на нем собирает фирма Sun сервера Sun SPARC Enterprise T5120 http://ru.sun.com/products/servers/coolthreads/t5120/. Изначально стоит Solaris. Процессор на нем не i32 или i64, а совершенно другой, т.е. там архитектура и устройство другое. Я уже не упоминаю об устройстве компьютера в целом.
И все ничего, на него линукс тоже встанет, только придется малость повозиться изначально.
ЗЫ: А вы спрашивайте, не бойтесь казаться неучами.  _________________ Мы кипим, мы парим, но все равно мы не паровозы. |
alexaga бывалый
Добавлено: 03.06.2008 23:23 Заголовок сообщения: |
Это не полемика. Т.е. тупой я. Что не могу ни где найти те самые бинарники для процессора у PS3.
К сожелению я не программист. И не могу написать драйвера. Если вы такой продвинутый то флаг вам в руки. Я тока рад буду и многие другие. Что хоть кто то взялся об продвижение PS3 не как консоль для игр, а как ещё не плохой ПК.
Так как сей дивайс у меня имеется. И к сожелению Линукс на нем с завода не стоит. А то ПО которое заложенно в ней он даже ставится на собственную файловую систему. Тут не надо путать. То что программеры сделали подарок своей "Жёлтой Собаки" это как бы сторонний проект PS3. Что даёт расширить её возможности. Но ещё всё так сыро. Так что у вас тут есть возможность к творчеству. Дерзайте. Сылками я тоже могу заволить. Но увы не программер я, а пользователь. |
BNX модератор
Добавлено: 04.06.2008 14:10 Заголовок сообщения: |
| alexaga писал(а): | | Что не могу ни где найти те самые бинарники для процессора у PS3 |
Хм. И я вообще-то сомневаюсь, что найдете... По причинам, совершенно правильно, указанным Vitalik Slivkov.
| alexaga писал(а): | | Сылками я тоже могу заволить. Но увы не программер я, а пользователь. |
А вы попробуйте отказаться от философии "потребителя". Для чего нужен Линукс - если даже не делать попыток изучить и понять эту ОС.
Да и не "по-чайниковски" это...
Для создания собственного дистрибутива вовсе не обязательно быть "крутым" программистом и в совершенстве знать С.
Дотаточно иметь время и желание разобраться. В сети полным-полно материалов о методиках компиляции (в т.ч. кросс-платформенной) ядер Линукс для различных архитектур.
Начните с прочтения доков по т.н. chroot окружению (среда компиляции программного кода для архитектур отличных от исходной машины - т.е. компиляция ядра для процессоров PowerPC на машине с архитектурой x86 и т.п.).
Очень хорошие доки по созданию собственного дистрибутива линукс - называются Linux from scratch - http://ru.wikipedia.org/wiki/Linux_from_Scratch
Ну и само собой без элементарного понимания вопросов конфигурирования ядра Линукс тоже далеко не уехать - так что welcome: http://lafox.net/docs/Command-Line-ru/compiling-conf.html
Ну и конечно www.google.ru _________________ Arvdr & XBMC, DM500 & 800HD, UFS910, CubeCafe, 90е to 9е, Stub HH100 & Mot. 2100, Toroidal & Of. 120 & 110 & 60
alexaga бывалый
Добавлено: 04.06.2008 15:00 Заголовок сообщения: |
| BNX писал(а): | | Хм. И я вообще-то сомневаюсь, что найдете... |
Я и не собираюсь искать. Так как это тока 10% от того что надо. Кроме бинарников надо знать как чип работает. Если уж кто то продвинутый в этом деле так пускай делает. Это действительно уже на полимику пошло. Что Линукс это самая, самая и не для всех, а только для продвинутых.
| BNX писал(а): | | А вы попробуйте отказаться от философии "потребителя". Для чего нужен Линукс - если даже не делать попыток изучить и понять эту ОС. |
Я уж давно отказался от фелософии. Изучить эту ОС не проблема и очень интересно. Можно сказать что освоил на 50%. BNX и благодоря вам. У меня не возникали вопросы. Как подцепить ту или иную железяку, как настроить софт. Т.е. задавал но все решалось просто чтение доков. Компилить ядро я знаю как но чтоб написать дрова для железяки - это иное.
Также выше был разговор об кодеках. Ну нечего ведь сложного. Читать доки и делать по инструкциям. Малость где подправить. Не проблема. Также и с PS3 как раз дистрибутивы на ядре PowerPC (https://help.ubuntu.com/community/PlayStation_3) ставится без особых проблем. Далее SUSE тож ставится с пол пинка. Дебиан. Но Убунта мне больше нравится. Вот и выбор на ней. А пусути отличий ни каких под каким дистрибутивом сидеть. Отличие лиж в оформление, ну и малость софта.
И также на всё это нужно время. У меня тож его не так навалом. Ведь нужно кроме хобби ещё и семью кормить. |
Pawel40 бывалый
Добавлено: 15.12.2008 14:08 Заголовок сообщения: |
Как прикрутить AC3 к Kaffeine 0.8.7 ? _________________ 1.2м супрал 36Е |
