SmartDVB - новая программа для sat tv
На страницу Пред.  1, 2, 3
cassel1
СообщениеДобавлено: 09.11.2010 12:05    Заголовок сообщения: Ответить с цитатой
SmartDVB016beta
http://www.ceibo.net/smartdvb/download/SmartDVB016beta.rar
chess-online
СообщениеДобавлено: 09.11.2010 15:51    Заголовок сообщения: Ответить с цитатой
И есть смысл тестировать? Чего там нового, вкратце?
cassel1
СообщениеДобавлено: 09.11.2010 19:21    Заголовок сообщения: Ответить с цитатой
v0.1.6 Fixed: 22 khz tone wasn't passed correctly in scanner.
Fixed: ctrl-click wasn't correctly selecting channels under windows 7.
Fixed: some changes to scheduler handling when restarting smartdvb through scheduler
Fixed: scheduler 'exit' option at end could also do a mistaken shutdown, fixed.
Added: diseqc delay and repeat options can be configured now through satellite settings dialog
Fixed: bug which could cause a crash in the connection dialog from the video popup menu.
Fixed: Restarting smartdvb from scheduler was not working all the time.
Added: added 16apsk/32apsk modulation support.
Added: New beta BDA driver supplied by user Florian and adapted by me.
Many thanks to him for his work. Please report any problems or success stories to me so we can improve this driver.
Added: visual studio 2010 is now used this means that older operating systems like windows2000, me, 98 will not work anymore from this version onwards
Fixed: Fullscreen freeze on windows 7 when using EVR should be fixed now.
Fixed: Snapshots were not working correctly with all renderers, should be fixed now.
Added: basic CI support, will only work with new bda.dev device. Technotrend/twinhan tested, firedtv untested.
Added: Automatic device restart to device dialog, so no need anymore to restart application when selecting another device.
Added: rolloff/pilot settings to new bda.dev.
Fixed: crash which could sometimes happen in codec add dialog
Added: Initial atsc support to parser (only tested for atsc 8vsb terrestrial for now, thanks to majortom for helping me on this)
Added: DVB-T transponder lists for various countries including offset support from the ini lists.
To accomodate for more dvb-t lists in the future ranges 10000-20000 are added and reserved for dvb-t lists.
Added: DVB-C transponder lists for various countries.
Added: ATSC QAM cable lists, QAM functionality untested for now.
Added: Basic ATSC eit (guide) processing.
Fixed: Many internal changes to speed up tuning, including quick directshow connect option which should not
clear the screen anymore.
Fixed: Some EVR optimizations on the graphs, when selecting 'quick directshow connect' no more black screens on EVR win7.
Experimental so if you experience any channel image problems while this is on turn it of and see if it works again.
Please report any problems you encounter with this setting on EVR.
СообщениеДобавлено: 09.11.2010 19:29    Заголовок сообщения: Ответить с цитатой
На официальном сайте нет ни каких сведений о новой бетке. На главной странице предлагают последний релиз V0.1.5a, на форуме в секции Beta Testing тестируют BDA-драйвера, на download тоже тишина.
cassel1
СообщениеДобавлено: 09.11.2010 19:52    Заголовок сообщения: Ответить с цитатой
Посмотрите тут:
http://www.smartdvb.net/smartdvb/download/
http://www.smartdvb.net/smartdvb/download/SmartDVB016beta.rar
evgen_ln
СообщениеДобавлено: 09.11.2010 21:59    Заголовок сообщения: Ответить с цитатой
Новая бета требует Распространяемый пакет Microsoft Visual C++ 2010, иначе будет выдаваться ошибка. По поводу этой беты я спишусь с автором и уточню, в местах обычного обитания он давненько не появлялся, для тестирования выкладывал только bda.dev.
49*23'08"N 27*06'42"
Страница 3 из 3
